Use a cell name to find the cell location with the Report Generation Toolkit
Hello all,
I hope you can help me. I want to find the correct cell location e.g. B2 if I use the cell name as a input e.g. "FindMe"
I think this must be easy I cant find the correct way to do this however. I am using the Report Generation Toolkit.
thanx for the help!
(1,462 Views)
This is possible, but requires using Excel Get ActiveX References.vi:
(1,451 Views)
If you want to write text to that location, use the "MS Office Parameters" cluster and the "name" string control.
aputman
(1,442 Views)
Hey Darren, thank you!
I cant select the "Range" option in the property node, I can only select "UsedRange" . Do you have got any idea what could be wrong ? I did also search for Cell1 it is also not there I can find "Cells
(1,387 Views)
Hello Darren, I did not look good enough at your example. I did use a property node but the first one needs to be an invoke node.
Now it works! thanx!
A related question would be, what can I search for (on www) if I want to understand the Methods provided and returned properties better? for instance a lot of data is returned as a variant. Without knowing the type it is hard to extract the correct data.
I did also take a look at other functions to get a better understanding of the code already written. I was wondering what this part does hope you can explain it:
Does it take a part of the report-in class ? Or is it used to check if the correct class is used?
Thanx !
(1,375 Views)
For your first question as to how to learn more about the ActiveX interface to Excel, there are two good resources:
1. Digging through the Report Generation Toolkit Excel subVIs.
2. The Microsoft website: Excel Visual Basic for Applications (VBA) reference | Microsoft Learn
For your second question, yes, I believe the code is making sure that the Report class that is wired in is an Excel child class. If so, it can perform the operation. If not (i.e. if it's an HTML or Word report), it returns an error.
(1,355 Views)
