Use PFI pin to trig ??
I would like to start oscilloscope (mode single) with a trigger. I have a PCI 6024E board. Can i use the PFI input like to a trigger for activate a Vi who send instruction to oscilloscope.
Thanks.
(3,054 Views)
Hi
You can use the PFI lines as trigger to the hardware. It means that you can setup your board to wait for the trigger signal on the PFI line. The board will wait for the trigger. The trigger will not activate the vi (sotware), but will start A/D conversion of the PCI-6024 (the hardware).
You can take a look on the example "Continuous Acquisition & Graph (Buffered) Using Digital Triggering" and then go to the function AISTART. This vi is calling the function Trigger Config. Take a look on the help description on this function. It explains how to setup a digital trigger by the PFI lines.
RKO
(3,054 Views)
By the way here are the places to find the trigger related examples.
LabVIEW Help>> Find Examples>> Hardware Input and Output>>DAQ >> Analog Input.
Please do let me know if you have any questions.
Sincerely,
Sastry V
Applications Engineer
(3,054 Views)
Thanks for your help ROtake.
(3,054 Views)
