Use LabVIEW in a portable devics,like mobile phone
Dear all,
Recently I have came up an idea that to use LabVIEW to write a programme.Then, put the programme in a portable device,like mobile phone. Smiley Very Happy
I am wondering to convert LabVIEW to java and put it in the mobile phone. Actually is it possible? Or there are another ways to put LabVIEW in mobile phone?
Thanks in advance,
Io
Message 1 of 8
(10,213 Views)
I don't know about mobile phones but LabVIEW is being used in PDA's, search the NI site for that topic.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 2 of 8
(10,202 Views)
I use Labview on the Pocket PC based phones, these are devices using WM2005/ WM6 they resemble a PDA with a phone added in, take a look at the HTC P3300 Artemis, a great unit for running applications on due to the inbuilt hardware BT, WiFi, GSM, GPRS, GPS so there is plenty to go at. You can also put an application on the MS Smart Phone although these are a little more difficult lacking the touch screen. I have no idea how you would port Labview through to Java though, the Labview plug in for PDA creates an exe file that you simply place on the PDA's storage card then run the app by tapping it using File Explorer, or link it to the programs section. - Mike
Message 3 of 8
(10,156 Views)
Hi.
Thanks for all your replies.Smiley Happy
I have also think of  using PDA as the portable devices but I am wondering whether PDA can support the Vision module.Since I have used the imaq functions in my programme.I am afriad that the exe programme may be too large for it to run and lose it's stability.
This is what I worry about the PDA.
Thank.
Io
Message 4 of 8
(10,036 Views)
The PDA module will not support image processing via IMAQ, the PDA simply wouldn't have the processing power to cope with such a task - Mike
Message 5 of 8
(10,027 Views)
Dear Mike,
Thanks for your reply.
If PDA cannot do that.Can the WM6 phone do that?Smiley Surprised
Since I have saw the suggestions and saw some information about WM6, it seems that it have much more power than PDA.
Am I right? If so, can it supports my imaq programme?
Thank you very much.
Io
Message 6 of 8
(10,028 Views)
Hi IO HUI,
Mike was right when he said the PDA module doesn't support IMAQ.  The Vision Module is only supported on Windows 2000, XP, or NT, and as a result will not work on devices running Windows Mobile or Pocket PC devices.
James R.
Message 7 of 8
(9,855 Views)
WM6 will make no difference to the PDA, further to that, the NI PDA module is not yet fully supported on WM6 devices, I have a couple of PDA units that I can run using WM6 or WM2005 by swapping out the ROM, Labview for PDA does work on the units with either OS installed but the newer WM6 does not release some magical capability of a PDA - the hardware is very limited in terms of what it can do, Labview PDA makes a very good job of taxing the limited capabilty of a PDA to the extreme IMHO.
If your application requires image processing, forget it as a PDA is at best taxed by taking a photograph at high res, let alone running image processing software - Mike
Message 8 of 8
(9,844 Views)
