Use LabVIEW FPGA to control a pendulum with motor
Hi everyone!
I'm controlling a pendulum with motor at the end using myRIO and LabVIEW. My topic is based on previous students' work. They built the pendulum and designed controllers with Simulink. I transfered the Simulink PID controller to LabVIEW and used the parameters in the Simulink PID controller.
However, when I was running the Labview program, the response was not like the simulation results in Simulink. For example, when I was setting the angle of pendulum to 3, the simulation result should be 3 degree in a short time, but the actual pendulum controlled by labview is about 20-30 degrees.
Can anyone help me to find the error or difference between Labview and Simulink program?
Thank you very much!
Kind Regards
Chenzhe Xiao
(2,614 Views)
I don't know how simulink works, but its probably a lot different than LabVIEW. What is your expected output from your LabVIEW code?
(2,515 Views)
I'm also not familiar with Simulink, but since this year MATLAB and LabVIEW are slightly more friendly with one another.
Taking a look at the Model Interface Toolkit (readme) might be useful if you're able to use 2019.
The notes describing the changes are here: NI-MathWorks CollaborationRunning Compiled Simulink Models in LabVIEW and in VeriStand.
GCentral
(2,508 Views)
