Urgent : Array Comparison
Hello, I need some urgent help if possible.
I'm fairly new to Labview but I do have a certain basics.
I'm trying to accomplish the following.
I have 2 arrays of the same size.
I'm comparing the elements of the first array to a certain value.
If some of the elements fits this requirement I want the compare the corresponding elements in the second array to another value.
If the elements of this second array are indeed greater then this new value I want to switch a boolean output to yes.
EXAMPLE!
Array1 =
1 2 6
5 4 9
3 7 2
Elements of Array1 > 5 ?
x x 6
x x 9
x 7 x
Array2 =
6 4 1
6 5 7
9 8 3
I only want to use the elements at the position corresponding to the elements from array1 that were greater then 5.
All other elements can be ignored.
New Array2 =
x x 1
x x 7
x 8 x
Elements of Array2 > 6 ?
x x x
x x 7
x 8 x
If Answer = 0 : Boolean = false
In this case : Answer = 2 elements : Boolean -> True
I could really use some help.
Any idea is welcome.
Thank you in advance.
(4,036 Views)
Accepted by topic author KLI
I would make both array comparisons.  You'd wind up with two arrays of boolean values.  Then AND those arrays together.  Now you have an array of booleans where a True means the element in the first array met condition 1 and the same element in the second array met condition 2.
(4,033 Views)
Nice Idea !
I will test this.
But how to know the positions in the arrays of these elements now?
(4,026 Views)
I am not sure I full understood but I threw this together really quick.
Seems to do what you wanted but it's ugly and I am sure there are better ways...
=== Engineer Ambiguously ===
(4,022 Views)
There are many ways to do this.
  • Do you really need to know the positions? If you just need to know of a TRUE exists in the output, do an "OR array elements". If the output is true, at least one element is true.
  • Use "boolean to 0,1" followed by "add array elements". The value will tell how many elements are true.
  • You could use two stacked FOR loops and build an array of the TRUE indices of the final array in a shift register.
  • You could reshape the 2D array to a 1D array, use search 1D array in a loop to find all TRUEs (here is example code that could be adapted)
(4,015 Views)
I responded to your duplicate thread and assumed single dimension arrays, so ignore my response.
(3,989 Views)
: Thank You
(3,964 Views)
