Updated "Xilinx Compilation Tools are not installed" thread for 2015
I have Labview 2015, I need to compile a vi for a Compact RIO 9081 fpga. I get the error "Xilinx Compilation Tools are not installed. Install them using the installation media or download from ni.com".
OK simple enough. What do I download from where? Is there a link?
These Xilinx tools don't solve the problem, which I only found out after downloading all 9 gigabytes:
http://www.ni.com/download/labview-fpga-module-2014/4845/en/
http://www.ni.com/download/labview-fpga-module-2015/5492/en/
Bonus questions: where are the instructions that specify what download links to click on for what hardware?
(4,087 Views)
Accepted by nickw1881
This KB should list out what compile tools you need for your specific target.
http://digital.ni.com/public.nsf/allkb/7CF3DD1ABBE6AE5886257EFB0006E303
It can be a bit confusing at first glance but you should need the Xilinx tools 14.7 for LabVIEW 2015 which you can download from the following link. It looks like you found the correct Xilinx version but it was for LabVIEW 2015 which is what I would guess is the problem.
http://www.ni.com/download/labview-fpga-module-2015/5494/en/
You can also try the compile cloud at ni.com/trycompilecloud
(4,080 Views)
well, I have the same error, 2015 labview - xilinx compilation tools 14,7 installed, all files for installation I got from NI tech support.... SW enabled in firewall, local compile server set everywhere possible, worker says taht connection to server OK. I hate this spaghetti hell....
(3,743 Views)
PJ,
The last comment in this thread was in February, so you may have better luck getting a response if you create your own thread. That said, what cRIO/FPGA target are you using? Certain targets require a specific version of the tools regardless of LabVIEW version.
(3,722 Views)
