Updated MongoDB Driver
Hello everybody,
I'm writting an updated driver for MongoDB in LabView. In the first moment, I thought it would be a C#/.net issue so it posted it in stackoverwlow:
https://stackoverflow.com/questions/61007633/labview-mongodb-driver-on-top-of-c-sharp-driver-no-getc...
But now that I have tried different versions of the C# driver, I think that maybe is a LabView issue.
Do you have any hint?
Thanks for your time,
EMCCi
(3,105 Views)
Hi Héctor,
I was trying to reproduce your issue, but since I know less than you about Visual Studio (that I'm installing just now) I ask you the favor to explain the procedure you followed in a little more detailed way than you did on Stack Overflow, also attaching some of your LabVIEW code if possible.
Thank you in advance, and best regards,
Alessia
(3,026 Views)
Hi alamanna,
I droped the project and I'm trying to do it in pure C. The problems is here:
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Generic-Class-Support-for-Net/idi-p/3091060
Labview doesn't support "generic classes". I have no idea what a generic class is, but they are defined with parameters between "<>" like <this>. Get collection whas a generic method so it isn't supported. I don't know nothing about C# and visual studio (also installed just for this) so I think I can't help you further.
Except that you could use the legacy version of the driver that isn't generic.
Best luck,
EMCCi
(3,020 Views)
