Update latest waveform of waveform array in graph
Dear GerdW,
- Why do you need to search for the changed array element when you already know which one gets replaced/changed in the case structure???
You are right! I already have the last updated waveform, so I just have to print it out.
@GerdW
- Why do you need to convert the boolean array to an integer array? You can also search a boolean array for a TRUE constant!!!
I convert to integer to find the sum of array and wire it to the second case structure. I cannot wire a boolean array to the case structure.
@GerdW
Which is overly complicated!
My solution is for assuming that I don't know what is the last updated waveform. Because in this VI, I know the waveform in advance so it does not present exactly what I want. That why I think the problem in this VI is trivial.
In your "original" problem you also know which part of your array gets changed: you calculate a (random) position in the left part of your while loop…
But how to extract only the last changed row? In this case the updated row is calculated from the beginning, not from the existed row. Also, the get variant function give me the ordered result so I only get the row corresponding to the largest position, not the last changed one.
Thank you!
Micheal
Message 11 of 13
(487 Views)
Dear GerdW,
From your suggestion, I found a solution for my problem in the attached file. Is it efficient enough?
Thank you so much!
Micheal
Message 12 of 13
(481 Views)
Hi Micheal,
I don't know. What are your requirements?
Message 13 of 13
(478 Views)
