Update from 2.0
I have to update VI to version 7.0 The VI have been programmed in version 2.0.
How should I proceed,
I can have access to labview version 5.0 to 7.0
Tx
(3,104 Views)
I'm not sure if LV 5.0 can load LV 2.0 VIs. If this is true first convert your VIs to LV 5.0 and then to 6i and then to 7.0.
If LV 5.0 cannot load 2.0 VIs contact NI support. They have a conversion toolkit which will convert all versions.
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(3,104 Views)
Hello Tx,
Unfortunately, LabVIEW 5.0 cannot convert VI�s from LabVIEW 2.0. Info about the free upgrade toolkit can be found here.
Have a nice day!
Robert M
Applications Engineer
Robert Mortensen
Software Engineer
(3,104 Views)
Hi Robert,
The Links that you put is broke, do you know another link to download the upgrade toolkit.
Tx
Frro
(3,104 Views)
I think this is the correct link:
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/429e45271cfd683786256d87006b1eef?OpenDocument
(3,104 Views)
