Update GPS Sentences
Only now looked at your code and know what you are missing: Loops keep running until you stop them and in that time they will only read controls INSIDE the loop. You could see what your program is doing by using highlight execution (light bulb on block diagram menu bar). Learn a little more about while loops: there is excellent documentation and examples on this website and inside labview.
Aart-Jan
Message 11 of 21
(1,868 Views)
Aart-Jan
Message 12 of 21
(1,868 Views)
Aart-Jan
Message 13 of 21
(1,870 Views)
Hi, I did tried your example in my GPS by connecting the LATs and the LONs together. But it didn't work out quite right. I've already posted my program earlier. My program includes the earlier example which you had provided me.
Can you help me have a look where is my error?
Thanks a million
From
Donny
Message 14 of 21
(1,868 Views)
Okay, I put that sub-vi in your code, but didn't try it out. Something like this should work for you.
Aart-Jan
Message 15 of 21
(1,856 Views)
Hi Aart-Jan,
I've discovered my error. Stupid me. Really hope to thank you in person. thanks alot 🙂
From
Don
Message 16 of 21
(1,856 Views)
wow, that is a lot of stars! thanks all.
I accidently posted one message multiple times, because I didn't see that they moved to a second page inside the thread.
Aart-Jan
Message 17 of 21
(1,843 Views)
Hi Aart-Jan,
do you have any good GPS programs on hand? Coz I'll like to understand more on the GPS stuff. Any GPS program will do, from the programs I hope to improve my Labview programming.
Thanks expert!!
From
Donny
Message 18 of 21
(1,834 Views)
Hello aartjan and others,
I'm looking for a vi that would do something of the same thing I guess. I'd like to find or come up with a vi that would read the Lat and Long coordinates from my GPS and display them on the front panel. And have these coordinates saved also. I'm using a USB Garmin GPS 18. Bu tI have access to an Garmin 76S serial port GPS, but the USB GPS would be used in my application. I have found the older Garmin 45 vi posted on this board, but cannot make much sense of it and I'm not sure if it would work for other GPS units or not.
Any help you could provide me with how to read the coordinates from my GPS unit would be most appreciated. I'm using Labview 7 Express (7.0 not 7.1).
Thanks for any help or advice...
Using Labview 7.0 and 2010 SP1 with Windows XP and 7.
Message 19 of 21
(1,754 Views)
As far as I know, the garmin 18 usb does NOT support NMEA. This is a real nasty development taking place at Garmin, trying to keep control on how people use their products. I think it only supports the GARMIN protocol. This is unlike the serial 18 model (which doesn't have the cool 1 cable configuration).
Aart-Jan
Message 20 of 21
(1,728 Views)
