Upconvert VI Requests
@Kant84 wrote:
Thank you for converting from 5.1 to 10, if possible...
i have the following messages:
"L'erreur 1126 s'est produite à : Ouvrir une référence de VI dans StockUnitMain.vi"
"Raisons possibles :
LabVIEW:  La version du VI est trop ancienne pour la convertir en la version actuelle de LabVIEW.
Une erreur s'est produite lors du chargement du VI 'DataSondeCumulIHM.vi'.
Erreur 10 au chargement : version du VI (5.1) trop vieille pour le convertir à celle de LabVIEW (10.0)."
You are missing several subVIs. Attached is what you posted, recompiled under 8.2.
Message 601 of 1,261
(1,250 Views)
I'm sorry, there is some missing files...
thanks !
Message 602 of 1,261
(1,244 Views)
thanks !
Still missing XPasTocm and YPasTocm and SireneGlobals and DataSondeCumul... That's where I stopped.
Message 603 of 1,261
(1,240 Views)
I sent you only files that need to be converted to LV2010.
All missing files are on my HDD and don't need to be converted.
Thanks.
(Your're so speedy !Smiley Happy)
Message 604 of 1,261
(1,233 Views)
(you need all missing files ?)
Message 605 of 1,261
(1,232 Views)
No, I just thought you did.
Message 606 of 1,261
(1,229 Views)
Thanks for making this thread.
The VIs I have are in version 4.0.1, and the labview program I used is in version 2009. Could you please help me to upconvert them? That would be very appreciated.
Message 607 of 1,261
(1,226 Views)
Hi!
Could you please convert the attached Labview file for me? Below is the info.
Thank you very much.
source LabVIEW 5
target LabVIEW 2009 sp1
Message 608 of 1,261
(1,221 Views)
attached is in 8.2, which you can open
Message 609 of 1,261
(1,218 Views)
@SERDARSOYLU wrote:
Hi!
source LabVIEW 5
Message 610 of 1,261
(1,217 Views)
