Upconvert VI Requests
Hi
I have a Labview Driver that was written in LV 4.0 and I would like to convert it to LV 8.5.
I would really appreciate if this can be done.
Thank you.
Message 591 of 1,261
(2,091 Views)
@nxb wrote:
Hi
Thank you.
attached is a version you should be able to open
Message 592 of 1,261
(2,085 Views)
Can someone help me to convert the driver for Santec Laser TSL210 from LabVIEW5.0 to a newer version such as LabVIEW8.6 or LabVIEW9.0, please?
Thank you very much.
Message 593 of 1,261
(2,063 Views)
Hi
I would like to ask for conversion from 3.1 to 9.0. Can anybody help me with it?
Thank You in advance.
Best regards
Barbara Zalewska
Message 594 of 1,261
(2,059 Views)
Hi
Best regards
Barbara Zalewska
Message 595 of 1,261
(2,058 Views)
attached is in 8.2, which you can open
Message 596 of 1,261
(2,049 Views)
It works great! Thank you so much. Cheers!
Message 597 of 1,261
(2,038 Views)
I am using the labview 7.2 version. I have programm with 7.2 version. This prgramm i want to run in 8.5 verson. I am using DAQ card PCI6024B. Can you conert the below programm in 8.5 version.
Prashant
Message 598 of 1,261
(2,027 Views)
Hi Prashant,
there is no LV7.2, your VI is saved with LV7.1 and you can load it with LV8.5 without any problems on your own...
Message 599 of 1,261
(2,026 Views)
Thank you for converting from 5.1 to 10, if possible...
i have the following messages:
"L'erreur 1126 s'est produite à : Ouvrir une référence de VI dans StockUnitMain.vi"
"Raisons possibles :
LabVIEW:  La version du VI est trop ancienne pour la convertir en la version actuelle de LabVIEW.
Une erreur s'est produite lors du chargement du VI 'DataSondeCumulIHM.vi'.
Erreur 10 au chargement : version du VI (5.1) trop vieille pour le convertir à celle de LabVIEW (10.0)."
Message 600 of 1,261
(2,020 Views)
