Upconvert VI Requests
I saved the VI in LV8.5. Try to open this in LV2010.
Message 1021 of 1,261
(1,380 Views)
HI.
Can someone upconvert me this lib from 4.0 version to 9.0?
New drivers for Hp I have.
Message 1022 of 1,261
(1,376 Views)
Thank you, but unfortunatly it didn't work, I now get the following error:
Fatal Internal Error: "MemoryManager.cpp", line 566
Message 1023 of 1,261
(1,372 Views)
@Tina2 wrote:
HI.
Download the updated driver: http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=36A7F6A5AF553389E0440003BA7CCD...
Message 1024 of 1,261
(1,360 Views)
Your issue is that one of the objects on the front panel is causing LabVIEW to crash when it tries to open it in the new version. This is not too surprising, given how unwieldy the front panel and block diagram is. You really need to refactor this VI. Attached is the code in 8.2. If you still have problems opening it, then you should contact NI tech support.
Message 1025 of 1,261
(1,357 Views)
Thank you for trying, still doesn't work unfortunatly...
I know... I know...
Message 1026 of 1,261
(1,355 Views)
Does someone can convert the libraries attached for LabVIEW 8.5 please?
Sincerely yours,
Message 1027 of 1,261
(1,340 Views)
Can someone convert this LLB from TTI?
Original labview version: 5
Current labview version: 8.6
Message 1028 of 1,261
(1,334 Views)
Sincerely yours,
Those VIs are written in LabVIEW 8.2. They can be directly opened in 8.5. Did you try?
Message 1029 of 1,261
(1,328 Views)
attached is in 8.2, which you can open
Message 1030 of 1,261
(1,325 Views)
