Upconvert VI Requests
There is no toolkit. You need to use a version of LabVIEW that's in-between the version used for the old VIs and whatever version you currently have, if the version you have cannot open the old VIs. That's why this thread (and the corollary Downconvert Requests Thread) thread exists.
Message 921 of 1,261
(1,177 Views)
Hello, I want to convert the attached Vi files from Labview 5 to Labiew 2010 (or at least something I can open in 2010). Thank you for any help you can offer!
Message 922 of 1,261
(1,170 Views)
attached
you were missing the globals.vi VI.
Message 923 of 1,261
(1,163 Views)
Thank you so much! What is the globals.vi VI?
Message 924 of 1,261
(1,149 Views)
Oh ok nevermind I see what you were saying. I have about 10 VI files I needed converted, but it only lets you upload 3 at a time. So I just uploaded the first three. Attached are the rest of the VIs if you can help me again. Thank you for your time and consideration!!!
Message 925 of 1,261
(1,148 Views)
can u help me to upconvert the vi to LV2010.
Message 926 of 1,261
(1,135 Views)
The following .vi's work when using TestStand 4.2.1.83 and LabView 2009; however, my end user has a TestStand Base Deployment Engine and is using Labview 2010.  Can someone please convert the files in the included attachement so that they will be compatible with the software that is present on my user's station?
Message 927 of 1,261
(1,122 Views)
OK. Attached
Message 928 of 1,261
(1,119 Views)
here you go
Message 929 of 1,261
(1,118 Views)
Those VIs were saved with LabVIEW 8.0. LabVIEW 2010 can open 8.0 files. You do not need us to convert them.
Message 930 of 1,261
(1,116 Views)
