Unwanted blinking
I can not understand why I have an indicator on the front panel that JUST do "run" begins to blink.
The only setting to blink I have given is that if the data acquired is off limits max and min, the indicator starts blinking. Even though removing the entire line of blink, it continues to do so. I do not think the two things are connetted.
Thank you very much!
(3,343 Views)
Maybe you need to initialise it to blinking->FALSE at the start of your program.
(3,339 Views)
Hi lallilu,
when you have set the "blinking" property of a FP element using a property node: that property stays set until you reset it to FALSE!
Deleting some wires in the BD doesn't change properties of FP elements…
(3,338 Views)
thanks!!
I'm new in labview world... so... How and what have i to inizialize to FALSE?
(3,331 Views)
Accepted by topic author lallilu87
Hi lillalu,
you need to write a FALSE to a "blinking" property of the FP element…
(3,329 Views)
Done!!! Thank you GerdW!!!!  🙂
GerdW ha scritto:
Hi lillalu,
(3,327 Views)
