Universal Dialog Box
I finally finished off my Universal Dialog Box and submitted it as an example program.
Message 1 of 16
(2,771 Views)
How do you open a .chm attachment?  Can't see much ...
Message 2 of 16
(2,717 Views)
Windows should know how to open it.
Attached are Word versions.
Message 3 of 16
(2,712 Views)
Windows may not open a compiled help manual, .chm if it is marked as Downloaded.  It will not open from network locations either.
Plug:
On a side note, NI, PLEASE bring back offline help!!
Message 4 of 16
(2,706 Views)
Usually we posting code without documentation, this time you share documentation without code 😉
Seems to be link was forgotten: Universal Dialog Box.
Plug:
To open chm you need to check last box in Properties Window (sorry for screenshot in German):
And to get Offline Help back launch small Utility
then
Sorry for German screenshots again, technically this tool is located in this folder together with Viewer:
But personally I also prefer old school light weight chm instead of this "monster" modern viewer, because its tooo slooow for me, even on the fast PC.
Message 5 of 16
(2,681 Views)
I mentioned that I had submitted it as an Example program, but forgot to include the link.
https://forums.ni.com/t5/Example-Code/Universal-Dialog-Box/ta-p/4375400
Message 6 of 16
(2,654 Views)
Drat.  I forgot that the Mac version of the LabVIEW function "Recursive File List.vi" gags on a symbolic path.
I'll fix it and release a Mac-compatible version.
Message 7 of 16
(2,594 Views)
I believe I've ironed out all the multiplatform compatibility issues.  Also simplified the installation process, and a little other cleanup.
Version 3.1: Universal Dialog Box - NI Community
Message 8 of 16
(2,509 Views)
Drat again.
I left remnants of debugging code in there, so the UTF-16 LE handling doesn't work.
Stay tuned.
Message 9 of 16
(2,457 Views)
@MichaelS78 wrote:
Plug:
OT: Use the installed program NI Help Preferences   to select the installed offline help viewer by default.  NOTE: NI rarely patches the offline content but keeps the online content updated as documentation issues are resolved.
"Should be" isn't "Is" -Jay
Message 10 of 16
(2,450 Views)
