Units error in LabVIEW 6.1?
Units do not multiply correctly,
and are dependant on the
order of input
(3,022 Views)
HI Blue Road,
It looks like you found a bug in the compound arithmetic function.
You should report this to NI support.
Ben
(3,022 Views)
This issue has been recently reported to us and it has already been sent to R&D. Thank you for your assistance in reporting this bug.
Ray K
(3,022 Views)
Should 2 months ago be considered "recently"?
Ray, you may want to talk with NI's Alejandro Asenjo.
(3,022 Views)
The problem is with the multiple-product control. The classic two-input multiplier control works fine.
The units of the wire hooked to the first input (top element of the resizable box) are multiplied twice (i.e., squared) The rest are handled correctly.
The fix is to make sure that the wire going into the top element has no units.
Thus rewire the control appropriately: If all the wires have units you need to add a new element on the top and wire a 1.0 constant to it.
If you are only using two inputs then you can replace the control with the classic 2-input multiplier.
(3,022 Views)
