Uniqueness of the array elements
I've got the 1D array of the DBL values.
How to quickly check all of they are unique?
(3,001 Views)
Index through the array in a loop.  Search that 1-D array for each element.  If the item is unique, there should be exactly 1 of that element in there.
(2,998 Views)
Sort. Then check each against its predecessor. Careful with equality checks, you may want to allow a small range to be considered equal.
(2,994 Views)
What happens if you're comparing two NaN entries in a numeric array?
Edit - by which I mean to say that, as usual, altenbach has a pretty good example of this - have a read through the comments here
CLA
(2,955 Views)
