Understanding DVRs
The key thing seems to be in the name NEW DATA VALUE REFERENCE.
I have thought of wires as variables before, because it's sometimes a useful way of explaining things to folks coming from another language.
I've heard it declared that variables are not wires but it didn't matter before.
But here's a case where it does matter.
NEW:  you're creating something that did not exist before.
REFERENCE:  it's not a thing, but a reference ('pointer', sort of) to a thing.
DATA VALUE:  The thing is a VALUE.  It is NOT a control (I knew that), it is NOT a wire, or even the contents of that wire. It is a DATA VALUE.  It has a DATA TYPE and it has a DATA VALUE. Period.
Wires come and go - the data flows down them, and off the ends and gets deallocated.
But this is a separate chunk of memory, which you allocate and initialize at CREATE DVR time, and it stays allocated forever (well, until LV decides your program is over, anyway).
Once created from a wire, the DVR has no association with that wire.  The wire can change as it will, and the DVR refers to the old value.  If I change via the DVR, the wire does not notice.
If I were to CREATE DVR in a loop, then every iteration allocates a new chunk of memory.
That means that if I want to share an instance of a class, I have to create a DVR and then use NOTHING BUT the DVR.
I have to use the in-place elements to dereference it, call the method, and re-reference it.
Yuck.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
Message 31 of 32
(1,585 Views)
Apparently you can only do that 2^20 times.
aputman
Message 32 of 32
(1,575 Views)
