Unable to remove VI from project
Hello!
I have unused VI in my project and want to remove the one. But "remove" button is unavailable. There are no callers for this VI, if this make sence. What is the problem?
Message 1 of 8
(4,108 Views)
Have you tried simply selecting it and pressing the delete button (keyboard)?
Humm...  Actually, you may need to right-click the folder in which it is contained and select (something like repair all discrepencies).  I can't remember the exact wording.  Once all discrepencies are removed, then the "remove" selection should be available.
Message 2 of 8
(4,105 Views)
Are you using auto-populating folders in your LV project ?
Message 3 of 8
(4,103 Views)
Thanks for help.
No, I don't use autopopulating folders. But problem solved somehow, I really don't now what happensSmiley Happy Today I open project and remove VI. Seems like there were a kind of conflict in memory with this VI.
Message 4 of 8
(4,065 Views)
Was the VI opened when you tried to remove it? Or a VI running?
Message 5 of 8
(4,046 Views)
No, I'm sure it wasn't. I performed a lot of things, including VIs opening and closing and LabVIEW restarting, but nothing had helped.
Message 6 of 8
(4,034 Views)
Hi Joe,
Was "conflicts" (instead of discrepencies) was the word you forgot to remember... ?! Smiley Wink
- Partha ( CLD until Oct 2027 🙂 )
Message 7 of 8
(4,024 Views)
Yes..  "conflicts" is probably right.. 😉
Going mostly from memory these days.... and unfortunately, the memory doesn't seem to cooperate 😮
Message 8 of 8
(4,007 Views)
