Unable to put a timed structure in a parallel for loop, error -808
If I try to place a Timed Structure in a Parallel For Loop, the TS needs a different structure name per instance to prevent collisions. However, setting the Structure Name node  to something unique per instance doesn't work, I get error -808. Have I missed something?
Thoric (CLA, CLED, CTD and LabVIEW Champion)
Message 1 of 9
(5,875 Views)
I get the same error even with N=1.
Marco
Message 2 of 9
(5,868 Views)
That got me thinking - something to do with the number of compiled parallel instances.
Indeed, the compiler creates a number of parallel instances of the for loop in the compiled code (in my case 8), and uses the number requested at the Parallel Instances terminal (just under the Iterations terminal), which is set to 2. Therefore the compiler has created 8 instances of the Timed Structure, each in its own for loop instance, but they all have the same defined Structure Name. When launched, there is an immediate conflict because they can't share the same name, and error -808 is launched before the set Structure Name function can change it. Hence the error still shows when requesting only one instance, because the other seven still exist.
I guess this means you can't have Timed Structures (or Timed Loops for that matter too) in a Parallelised For Loop?
Message 3 of 9
(5,865 Views)
I'm afraid you are right,
but then why the "find parallelizable loops" tool doesn't warn us of the issue?
Marco
Message 4 of 9
(5,854 Views)
Hi Thoric,
I've replicated the issue and will be submitting a corrective action request when I can to R&D, who should decide on the best course of action.
I will post the reference when it is available.
Ben Clark
Message 5 of 9
(5,821 Views)
Thanks Ben 🙂
Message 6 of 9
(5,790 Views)
No problem, It's now in the capable hands of R&D!
Ben Clark
Message 7 of 9
(5,754 Views)
Any sign of a CAR# yet?
Message 8 of 9
(5,734 Views)
Yes sorry, I did say I was going to post that but I managed to miss it.
It's CAR #374805
Ben Clark
Message 9 of 9
(5,714 Views)
