Unable to locate LabVIEW Run-Time Engine
Hello
After install updated test application on my tester , I get the following error 'Unable to locate LabVIEW Run-Time Engine' . When I reverse back to old test software still work ok. Any one have an idea why new test application doesn't work on my tester. I checked with friends they are using new test application and no any issues.
(1,474 Views)
The updated test installer might not include a run time engine (this is optional, and you might not even use an installer).
If the undated test installer requires a different run time engine (e.g. newer or different bitness) it won't work with the installed run time engine.
Why would you tag this post with LabVIEW NXG or NI Product Announcement??
(1,464 Views)
