Unable to install offline VIPM package
Not sure where else to post this, but I am trying to install the grpc-labview packages which can only be downloaded, not installed directly from VIPM. When I download the package and double click, I get this error:
The open-with options is as follows:
Any ideas on what is wrong with the local vip install?
(2,563 Views)
Hi Chris,
did you try to open the vip using VIPM? (Start VIPM, then File->Open…)
(2,551 Views)
I reverted to VIPM 2020.3 and was able to install the local packages. Not sure if it is an error in the latest release or if I just needed a fresh install.
(2,548 Views)
My version of VIPM doesn't have a file menu option. Probably need a paid version to get that I guess.
(2,544 Views)
Hi Chris,
I'm sorry!
Today I used VIPM2016 at work to install a vip file residing on my harddrive - using the File->Open… menu. (Working flawless.)
Now at home I also see no File menu on VIPM2020 anymore…
(2,536 Views)
The menu bar is hidden by default, but you can show it by clicking on the toolbar:
I'm using VIPM 2021.0
Saludos.
(2,515 Views)
