Unable to get application to build -- error copying files
Trying to build an application (which has been built with the same build spec in the past). But partway through I get this message and the build fails:
_____________________________________________________________
error copying files.
Source: C:\Program Files\National Instruments\LabVIEW 2017\help\_LaunchHelp.vi
Destination: C:\_Development\Neural Suite\Builds\Neural Vision Suite V4\Executables\Production Generic.exe\1abvi3w\help\_LaunchHelp.vi
Invoke Node in AB_Source_VI.lvclass:Set_VI_Path.vi->AB_Source_VI.lvclass:Copy_SourceItem.vi->AB_Build.lvclass:Copy_Files.vi->AB_Application.lvclass:Copy_Files.vi->AB_EXE.lvclass:Copy_Files.vi->AB_Build.lvclass:Build.vi->AB_Application.lvclass:Build.vi->AB_EXE.lvclass:Build.vi->AB_Engine_Build.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyCaller
<APPEND>
Method Name: <b>Set Path</b>
Error 7 occurred at AB_Source_VI.lvclass:Copy_SourceItem.vi -> AB_Build.lvclass:Copy_Files.vi
Possible reason(s):
LabVIEW: File not found. The file might be in a different location or deleted. Use the command prompt or the file explorer to verify that the path is correct.
Nonexistent GPIB interface.
_______________________________________________________________
I navigated to the path of the _LaunchHelp.vi in Program Files and it is most definitely there, so I'm not sure why LabVIEW is unable to find the file. Any ideas why this is failing?
Thank you!
Michael
Message 1 of 13
(5,453 Views)
Additional Information! This error only occurs when the destination for the application is on the C:\ drive. When I move the build location to my personal network drive, it builds just fine...
Message 2 of 13
(5,452 Views)
Are some of the destination paths very long?
Message 3 of 13
(5,439 Views)
This is the path that the file is supposed to save to when the build errors. C:\_Development\Neural Suite\Builds\Neural Vision Suite V4\Executables\Production Generic.exe\1abvi3w\help\_LaunchHelp.vi
There aren't many paths much longer than that. Maybe 1 layer deeper, 2 at most.
Message 4 of 13
(5,436 Views)
Sometimes build errors are caused by your antivirus program grabbing onto a file, and my workaround for that is the same as yours, to build on a network drive.
Message 5 of 13
(5,427 Views)
I didn't count that out.  But, is it longer than 140 characters?  If so, that is likely what you're running into.
Message 6 of 13
(5,420 Views)
I'm not sure, but I will check! I thought the char limit was greater than that, so that could be the problem
Message 7 of 13
(5,393 Views)
It should be 260 characters, I think 140 is for twitter 🙂
Message 8 of 13
(5,389 Views)
This path: C:\_Development\Neural Suite\Builds\Neural Vision Suite V4\Executables\Production Generic.exe\1abvi3w\help\_LaunchHelp.vi
Is 121 Characters
Message 9 of 13
(5,387 Views)
There are too many character requirements these days =/
Message 10 of 13
(5,380 Views)
