Unable to get application to build -- error copying files
I brought the build destination up a few levels in case that was the problem. It was not. The error above seems to show up only after a build has failed and the failed build files are not deleted.
After deleting them and retrying, I received this error instead:
Error 8 occurred at Delete in AB_Engine_Delete_Internal_Files.vi->AB_EXE.lvclass:Build.vi->AB_Build.lvclass:Build_from_Wizard.vi->AB_UI_Frmwk_Build.lvclass:Build.vi->AB_UI_FRAMEWORK.vi->AB_Item_OnDoProperties.vi->AB_Item_OnDoProperties.vi.ProxyCaller
Possible reason(s):
LabVIEW: File permission error. You do not have the correct permissions for the file.
DMA hardware error detected.
C:\_Development\Neural Suite\Builds\Neural Vision Suite V4\Executables\Production Generic.exe
Sooo. For the moment, the only solution is to build to a different/network drive.
Message 11 of 13
(1,018 Views)
Do you have an antivirus program that you can temporarily disable?
Message 12 of 13
(1,015 Views)
There is a program called Webroot SecureAnywhere on here, but I unfortunately don't have permissions to disable it. That may be a solution I can try at a later time.
Message 13 of 13
(1,011 Views)
