Un-hide control
I'm working on LabView 2013 on a set of VI with hidden controls.
I need to rename one of such controls but even If I can find a reference of it, locate it on the front panel I cannot open
its properties to make any change.
I know it's a newbie question but I searched the forum and found no solution.
(1,376 Views)
Accepted by topic author michele.santucci
Hi Michele,
Simple solution: find the control terminal in the block diagram and change the label there...
Other simple solution: find the control terminal in the block diagram, right-click and "show the control" to un-hide it...
(1,373 Views)
There are no way to un-hide a single control or all hiddend controls?
(1,358 Views)
Hi Michele,
Sure there is a way!
The make ALL controls visible you can use property nodes: get the references of all frontpanel elements and set the visibility property for all controls to TRUE...
(1,351 Views)
I'm working on LabView 2013 on a set of VI with hidden controls. [...]
In newer versions of LabVIEW (at least >= 2022) there is a "Show Hidden Controls While Editing" entry in the "Edit" menu of a VI, but I see you are working with LV2013.
(1,320 Views)
