USB8451 with ADXL345 in SPI mode
I try to grab date from the adxl345 in SPI mode by using USB 8451.
In order to make sure that adxl345 is working, I used microcontroller (adruino) to control adxl345 and obtain data from them.
It is working well. But when I try to do the samething in the labview,  I get nothing from the adxl345.
In order to simplify my problem, I try to write a single data (0x08) to a register (address 0x2D) and read data from this regisitor again.
After exciting this program shown below, I get a value (0x00).
Anyone can give me some hint to solve this problem.
Best,
(3,403 Views)
You might need to check the command format: for example, some device need an opcode to write before your address and data.
The shipping example of 845x "ATML AT25080A" just demonstrated this.
(3,379 Views)
Based on a quick scan of the datasheet, your commands don't make any sense. In the first call you're trying to write a value of 8 to the 2D register, which is the POWER_CTL registers. Well, that register has the MSB hard-coded to 0, so setting the register to a value of 8 makes no sense. In the second call you're trying to access register AD, which doesn't even exist.
(3,372 Views)
To check an ADXL345 you could use the following VI. It read the 0 register. If all is OK you get E5.
Note: SPI connections are tricky. Read data sheets carefully, My first try don't work because SDI and SDO were permuted...
(2,913 Views)
