USB to SPI Converter
HiI'm trying to use USC-216 Isolated USB to SPI Converter with Labview.But I can't communicate with the unit Is someone familiar with this converter?Best regardsGuy
(4,141 Views)
Accepted by Guyco
I may be difficult to find someone who has direct experience with that particular device. What kind of programming interface is provided with it? Do you have a DLL? Does the manufacturer provide any example source code (probably in C)?
(4,121 Views)
Sorry about the late response
I don’t have sample code but after I created inf file with NI driver wizard I managed to see the device by using VISA.
Now my problem is that there is no response from the device
The device is in bulk mode using endpoint 0 for enumeration, endpoint 1 for reception (IN endpoint) and endpoint 2 for transmission (OUT endpoint)
Can you help me?
Thank's
Guy
(4,086 Views)
Unfortunately, I don't have experience in doing USB raw bulk mode. You would need to get detailed information from the manufacturer as to what data to send/receive from the device. You could also do a general search on doing USB raw bulk communications.
(4,075 Views)
UPDATE: Ran across a post from Dennis replying to another user asking about USB Raw vs USB Instr. He pointed out Intaris' post a while back on USB which I think you will also find useful.
(4,068 Views)
