USB read data
Dear Friends;
I want to read USB data from any known or unknown USB device. for example I want to read USB data from USB mass storage devices or read from unknown programmer devices that use USB connection for communication to PC.
Is this possible?
Is there a way to read USB data as easily as read serial ports data?
Can I listening or spying USB ports via reading it?
If I can please help me about it.
Thank you.
(18,809 Views)
Do you have a driver for the device? That's the easiest way to do it. Otherwise, you have to resort to USB RAW. See here and here [link removed; example no longer available].
(18,792 Views)
Hi ,
I know it has been some time since you posted this thread. I came across it as I also faced the same problem. I'm a beginner in LabView but I need to learn to use it for my school project and urgently needed a solution. I need to connect a USB device to my laptop. This device acts as a receiver that constantly receives signal(waveform) from elsewhere. I want to know how am I going to receive and display the signal using LabView. I have my device driver as well. Pls tell me a way how to go about this. Thanks so much for your help.
(18,113 Views)
Is this the same question you asked here? Basically what Dennis said is the same thing I would say: what information/software library did the vendor provide? Please continue the discussion in your original thread.
(18,094 Views)
