USB devices block my Labview Program
Sounds to me like you're blocking your event handler due to some system event. The fact thst you see a freeze after a keypress would support this.
Message 11 of 20
(1,432 Views)
But what he says is whenever he connects any usb device than it freezes.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 12 of 20
(1,425 Views)
I'm fully aware of that. Without code we cannot know what is going on in the event loop (if anything). The freezing action sounds like an event structure problem. How the usb leads o this I cant say without code. It could be a trivial loop termination problem with the freeze as an unwanted side effect
Message 13 of 20
(1,422 Views)
Correct. But where is the problem facer buddy .we need to hear from him. May be he also doesnt know the problem or cause.
--Ranjeet
Message 14 of 20
(1,420 Views)
Thank you guys ..
The programs is block with some USB devices , not all , for example  an USB modem or the USB keyboard , ..
The USB modem block the program automatically , when the O.S detect the connection.
The USB keyboard , in other hand ,  only block the program in one case when I use some features in other programs ( not related with Labview at all ) and I need to push one key and move the mouse through an image ( to see the pixel amplitud for example ) I repeat this program is not related with Labview. If I do the same with and PS/2 key board , it does not  happen .
The problem is that I don't have access to the code , it is developed by a third party and they said , and it is true , that the system is working in other computers ( of course this is one of the first with windows 7 ).
Message 15 of 20
(1,409 Views)
I truly don't mean to be facetious, but what's a "problem facer buddy?"
Bill
CLD
(Mid-Level minion.)
Message 16 of 20
(1,399 Views)
the guy who is facing problem. Not exactly to correct word to point a person. Nothing personal
--Ranjeet
Message 17 of 20
(1,385 Views)
@JuanPablodelvalle wrote:
[..]The problem is that I don't have access to the code , it is developed by a third party [..]
And what is it that you can do about this?
I understand that the software is not changable for/by you and, on the other hand, you can do nothing about the hardware setup.
So what is it what you can do where we can help you with?
Norbert
Norbert
Expert: Geometry
Message 18 of 20
(1,378 Views)
This is actually very difficult stage. better talk to the third party person and discuss the issue. He can surely help you as he may intentionally doing this.
--Ranjeet
Message 19 of 20
(1,376 Views)
LOL - okay I got it.  Forgive my brain cramp.  Thanks.  🙂
Bill
CLD
(Mid-Level minion.)
Message 20 of 20
(1,363 Views)
