USB VISA WRITE 4 bytes to FPGA
Capture2qeq.PNGis it correct now ?
 i am new to labview.
Message 11 of 16
(860 Views)
Hi Rajesh,
is it correct now ?
Atleast you built the same code as I have shown in my message.
You still need to wire the VISA reference, include some error handling, and so on…
There is a Training section in the header of this LabVIEW board!
(You should learn to spell LabVIEW the right way. 😄 Apart from spelling you also should learn to use the AutoCleanup tool…)
Message 12 of 16
(855 Views)
thank you so much 🙂
i will go through the classes.
need suggestion:
my VI should perform first WRITE then READ . how to control flow.
how to implement .
Message 13 of 16
(848 Views)
Hi Rajesh,
In those lessons you should get notified about the ExampleFinder in LabVIEW!
need suggestion:
To learn THINK  DATAFLOW you could use any example VI in the ExampleFinder!
Message 14 of 16
(845 Views)
Everything provided to you this far is correct and good.
however.....
USB control of devices which don't correspond to one of the standard USB device types (Mass Storage, Audio, HID etc) is challenging.  I've written posts on this in the past and it's actually very complicated if your device isn't one of the standard device types.
Do you have a VID and PID of your device so that I can do a quick check. If it's a custom USB device, this will not be a task for a beginner.
Shane.
Message 15 of 16
(838 Views)
My device has VID & PID.
i followed "http://www.ni.com/tutorial/4478/en/" procedure to detect my device as USB.
Message 16 of 16
(830 Views)
