USB Stage Motor anyway to move in arc or circle motion
Labview beginner here, trying to create a simple VI to have a two-axis stage motor move a desired circular path a certain number of runs. I thought this would have been more straight forward but I guess not.
I have the correct ports connecting the usb to the stage controllers and can create a simple script that runs the motors linearly.
However, I can't seem to find a circle or arc motion controls that doesn't require a BoardID. Any ideas?
Stage motors and controllers are Sigma Koki, if that's of any relevance.
(3,504 Views)
From my point of view there are two possible options:
A)     The difficult one: Program Midpoint circle algorithm (Bresenham algorithm), create a matrix and then analyze the next step for each motor, and of course synchronize the movement of the motors.
B)      Use the NI-Motion Software. This software will allow you to easily configure any kind of pattern needed.
https://www.ni.com/en/support/downloads/drivers/download.ni-motion.html
https://www.ni.com/docs/en-US/bundle/372134f/page/download.html
Of course, the first one will be the most difficult but the second will require an extra budget.
(3,472 Views)
Unless you're going to do very slow moves or the accuracy of the arc isn't important, this will be impossible. You need continuous control of the motors and a desktop operating system (I assume you're on Windows) can't guarantee that level of timing precision, in LabVIEW or any other program. Many motor controllers have built-in commands to do arcs; does yours?
(3,465 Views)
thanks for your reply, in my version of labview (8.5), there's a "NI-motion" segment with an Arc-Trajectory VI but this requires a BoardID, similair to the draw-circle VI which requires a same BoardID.
Is this the NI-Motion portion of the software that you mentioned?
(3,447 Views)
The only controllers from the stage controller company is in a line; so no, no provided arc controls.
(3,446 Views)
