USB 9211 Plotting problems
Hello:
Running a VI using a USB 9211 thermocouple module read ever second within a while loop and plotted over a 4 hour period.  The plot is beautiful, until I start a second VI that uses (2) DIO-96 PCI Cards that scans 80 lines every 3 seconds.  The temperature plot then occasionally jumps to the 25 C junction temperature value and then back to the correct value.  Any ideas how I can prevent this from happening?
Thank You!
(2,922 Views)
Hi GE Osmonics,
Just a couple of things to try and narrow down the problem:
- When, you start the USB vi, then start the DIO vi and then stop the DIO vi, does this behavior continue to occur in the USB vi?
- When you say occasionally jumps to 25C. Is this every few seconds or hours? Could you please give me a better idea of this?
- Does this happen if you have both vis integrated into one vi (both segments running in parallel)?
Please let me know. Thanks!
Steven C
(2,910 Views)
Hello:
The Jump to 25 C last 3-5 seconds and happens only when the DIO VI is running.  If you stop the DIO VI the temperature plot is smooth and steady.
Thanks for your attention
(2,903 Views)
Hi GE Osmonics,
A couple of other things to see if we can detemine wether it is a HW or SW problem.
What do you see, when you run the DIO vi and a test panel (in MAX) at the same time for acquiring temperature? Also, what happens when you run your Temperature vi and a DIO test panel? Please let me know. Thanks!
Steven C
(2,880 Views)
