USB-8506 LIN module
I would like to know if the USB-8506 LIN module (two ports) really works in parallel mode.
I have two DUTs and I’m using LabVIEW with two VIs running in parallel, each one using a different port. However, in practice it does not seem truly parallel. When I send a COMMAND to the first DUT, the second one does not work at the same time. It looks like the transmissions are sequential rather than simultaneous.
Has anyone experienced this behavior?
Does the USB-8506 support true parallel communication on both LIN ports, or is there an internal limitation?
Thank you.
Message 1 of 1
(39 Views)
