 johndg
			johndg
			01-12-2006 02:42 PM
 Kenny_K
			Kenny_K
			01-12-2006 04:01 PM
 2c worth
			2c worth
			01-12-2006 08:40 PM
01-13-2006 11:37 AM - edited 01-13-2006 11:37 AM
Message Edited by Otis [DE] on 01-13-2006 11:37 AM
Message Edited by Otis [DE] on 01-13-2006 11:38 AM
01-13-2006 12:02 PM
 David_49
			David_49
			12-13-2006 10:30 AM
Hello Kenny,
I'm intersted in having your program for the AD590 and USB6008.
Can you send it to me at this email : dlemarechal@bmp.fr ?
Thanks in advance,
David.
 Adzel
			Adzel
			01-23-2007 11:51 AM
In the above posts could someone please explain to me what the following means:
"I have it wired as a differential input with a floating signal source. I've installed 10k ohm resistors for bias current return as instructed. "
I realize this is over a year old. I am new to LabVIEW. I have my thermocouples installed differentially. When I put the 10 k resistor across the positve thermocouple wire input to a GND the readings did improve. Obviously this cuts down on the noise I was seeing. The readings look better. But bias current return seems arcane to me.
Please explain if possible (or direct me to an appropriate link)
Adz
01-24-2007 03:04 PM
 josh2.0
			josh2.0
			03-24-2010 06:50 PM
Hello Kenny K, I actually hav purchased the AD590 and still get random values when tryiing to read the temperature.
could I take a look at that program you said you have for the 6008/9??
Josh
 josh2.0
			josh2.0
			03-24-2010 07:18 PM
I would be interested in having this program.
Here is my email : joshua.goddard86@gmail.com
Josh
