UI bugs(?) when Tab control partially covers other controls and indicators
Hi @RT SLVU,
Unfortunately this workaround won't do for me.
Also I can't open your example VI because I'm running on LV2021 🙁
Habil
Message 11 of 16
(832 Views)
Thank you Bert,
Although it's not the most elegant solution, it works well!
I will probably make use of it in my application.
Habil
Message 12 of 16
(832 Views)
@habsilva wrote:
The ASML "thingy" is just my wallpaper.
I'm resizing the front panel window to cause the issue to manifest and the screen grab tool is then capturing the background -- that's what you're seeing there.
I've attached a simple VI that easily reproduces the problem described.
If you click on the Reveal Panel button, the right-hand "panel" is extended on top of the chart and the Z ordering works well; when the "panel" is concealed the glitch is made apparent:
I still can't reproduce it, making me think even more my theory is correct. It could be a mix though.
It could also be graphics card specific.
Message 13 of 16
(825 Views)
@habsilva wrote:
Seems like a legit bug. How do I report it?
On the bottom of the page, under Support, select "Submit a Service Request":
If they accept it as a bug, and it's a new bug, you should get a bug numbers (used to be a CAR)...
Then you wait for a few years, until it's fixed or until you give up.
Message 14 of 16
(823 Views)
FWIW it happens on my machine with LV2020, 64-bit, Windows 10, GTX1050 (in a laptop), running displays through USBC hub. Might help track things down.
Message 15 of 16
(789 Views)
The proposed solution -- using a transparent 2D picture control placed underneath the Tab control's page tab -- works with the Chart (and I'd guess that with other 'simple' indicators as well), but doesn't work with a subVI panel.
Even when the Tab control is fully revealed, it still gets overdrawn...
This is really obnoxious...
Message 16 of 16
(783 Views)
