UDP protocol
Hi everyone,
I created an FSK modulation software in labview. Now i have to collegate the transmitter to the receiver so that the modulate signal is sent by udp and received by yhe other udp block. I 'm not able to connect the two blocks . I hope you can help me.
(3,631 Views)
What do you mean by "collegate"?
We can't help you because you haven't attached any code so we can see what two "blocks" you can't connect together.
(3,607 Views)
Thanks for your answer. This is the file and I need to create two blocks for the transmission and reception of the modulated signal.
(3,560 Views)
I don't know what you mean by "two blocks" for transmission and reception.  Are you talking about LabVIEW subVI's?
Look in the example finder for UDP and you'll find some examples.
In your VI, I see you use a lot of local variables.  You should place those two control terminals on the top level of the block diagram and use wires to all the locations that you have local variables.
(3,555 Views)
I want that the modulated signal enter in a trasmission block and it will be sent to the receiving block that demodulate it.
(3,546 Views)
Help >> Find Examples >> Search >> UDP
You'll see Simple UDP.lvproj
What "blocks" are you talking about?
(3,542 Views)
