UDP close causing error #1
hey
i have written a simple VI to stream data acquired from a DAQ card over a network using UDP packets. it is working fine, but when i terminate the program the UDP Close VI is causing error #1 to occur. does anyone know how i can solve this problem?
i have attached a gif of most of the block diagram.
(4,262 Views)
Try replacing the tunnels that bring the UDP conncetion reference in and out of the For loop in the bottom loop with a shift register.
If the For loop iterates "zero" times the contents of its output tunnel will be the default value.
That would in turn pass a null refnum to the close.
Trying to help,
Ben
(4,257 Views)
Just to clarify what Ben just said:
  1. Using Tunnel (your code): If the FOR loop iteration count is zero, the UDP reference output from the loop is reset to default.
  2. Using Shift register:  If the FOR loop iteration count is zero, the UDP reference is output unchanged from the shift register input and is thus valid.
(4,252 Views)
