UDP Write
I am trying to send flattened data of images through UDP in a wireless network of sizes of around 8000 bytes. After sending around 50 frames , the UDP write gets stuck. It doesnt return error and it doesnt even time out (I have 10 sec time out time).
Is it because of the size of data?
Message 1 of 18
(5,609 Views)
Hi aman_bajra,
i think 8 KByte are not so much, can you show your code?
Mike
Message 2 of 18
(5,591 Views)
How fast are you trying to send them? You may be filling up the OS buffer. Keep in mind that UDP does not guarantee that you'll get all the packets at the receiving end, or that you will actually get them in the right order. I agree that if you post your code it may be easier to help.
Message 3 of 18
(5,581 Views)
Thank you for your suggestions. It did give me something more to think about. I have attached my code herewith. The green sub-vi collects the error like time out error. If it is because of filling up of OS buffer , how do I find the buffer level?
Message 4 of 18
(5,564 Views)
I am sending it at the rate of 5 frames per second. I am using 3G network.
Message 5 of 18
(5,563 Views)
Hi Aman,
When you say it gets stuck what do you mean?  Does LabVIEW stop responding?  How do you stop the VI from executing?  Does the abort button work or do you have to shutdown LabVIEW?  How do you know it gets stuck at UDP write?  What happens to the processer usage when your VI gets stuck?
Message Edited by Adam_H on 12-15-2008 04:58 PM
Adam H
Message 6 of 18
(5,527 Views)
Hi Adam,
I used the highlight execution button and it showed me that the program is waiting for UDP write to finish. Even when I press the abort button, the program doesnt stop. If I click the X  to close as in every window, a small window appears and it says LabVIEW is waiting for the program to finish.
Aman
Message 7 of 18
(5,519 Views)
Hi aman,
What happens to your processor usage when it is stuck?  Is LabVIEW using lots of processing power or is it sitting idle.
Adam H
Message 8 of 18
(5,500 Views)
Hi Adam,
When that happens, I found that LabVIEW is using around 94 MB of memory which I think is quite normal because even when the program is not running it is using around 67 MB.  Btw what does the amount of memory being used tells about the source of error?
Aman
Message 9 of 18
(5,478 Views)
Hi aman,
I was actually looking for the how much of the processer LabVIEW is using not how much memory.  If you take a look at the image below I need the number highlighted.  I need this information for while the VI is locked up and while your computer is idle.  This will help me know if the VI is completely using your computers resources or if maybe it has stopped executing.  It would also be good to know what version of LabVIEW you have and what you are trying to communicate with. Is the communication going over a network or to another computer through a crossover cable?  How reliable is this issue?  In words does it happen every time you run it or will it sometimes work and sometimes not?
Adam H
Message 10 of 18
(5,448 Views)
