UDP Receiver Data issue - Xilinx
Hi team ,
I am new to this Protocol and Software .
I am using xilinx - vivado AC701 Kit . I need to capture a data from that kit using the Ethernet Port configured .
For checking the proper channel and pockets which was transmitted and received was validated by Wireshark Tool . i validated in that tool by capturing the specific number of pockets  and verified .
In labview , i started by simple UDP example program and tried out the multicast UDP example also . for capturing the data from xilinx board over Ethernet port .
I checked the proper timeout was there like that . But no data was received from the receiver side example program .
Note : I dint Run the sender program vi in that example project , because this xilinx AC701 kit will already provide a data transfer over a specific port address ( Port number : 36636 )
attached the Xilinx datasheet procedure. Kindly Go through and guide me to move forward
Message 1 of 1
(1,443 Views)
