U-shaped pointer slide indicator
Hi there, I was wondering if it is possible to create a custom pointer slide indicator having a U-shape, going from -100 to 100.
I am not able to do it from the "Advanced<Customize..."
Any help would be much apreciated.
Moe
Message 1 of 12
(4,420 Views)
The Advanced, Customize option should let you do what you want.
Try these steps...
1) Create an image of your 'U-shape'. PNG format seems best. Powerpoint can be handy for this.
2) Drop a slide control onto your front panel
3) Go to Advanced, Customize.
4) Click the spanner icon at the top left so that it turns into a pair of tweezers.
5) Click the slider so that it is selected
6) Right mouse click on the slider and 'Import from file...' or 'Import from file at same size'
7) Select your U shape image
😎 Sit back and bask in the glory of your custom control
See attached for example.
Message 2 of 12
(4,405 Views)
Nice one...
Da Helmut
Voir le profil de Maxime M. sur LinkedIn - View Maxime M.'s profile on LinkedIn
Message 3 of 12
(4,400 Views)
@helmut O'Brian wrote:
Nice one...
Well if you liked that one, see Yair's Nugget on customizing controls here.
He showed us this
Which inspired this boolean
and latter this crazy form of a tab control.
Ben
Message 4 of 12
(4,381 Views)
Try these steps...
thanks Ian,
but actually what I want is a U-shaped "scale" not the pointer itself. Is it possible?
Message 5 of 12
(4,374 Views)
Please post a mocked up image so we can see what you are thinking about.
Will the scale range ever change?
Ben
Message 6 of 12
(4,365 Views)
Ben
Hey Ben,
Here what I was thinking of, with a fixed scale (-100 -> 100) and different colors for different ranges. And the black dot is the slider.
Thank you
Message 7 of 12
(4,350 Views)
Turn a guage upside down (adjust the scale start stop angle) and replace the needle with a dot.
Ben
Message 8 of 12
(4,340 Views)
Ben
... or use a knob and rotate the numeric display a bit. This still ends up as a circle rather than a U, but you could get creative with customisation and pop some graphics over the top to hide the upper part of the knob. Careful use of transparency in the blocking graphics could make it look reasonably effective.
EDIT: Apologies Ben, I just realised that I've said effectively the same thing as you! Doh.
In case anyone is wondering how to adjust the start/stop angle (I only just discovered this), put your mouse over the little line/tick marks on the first and last digits of the control. You get a little curved arrow icon which allows you to rotate and respace the numbers around the dial.
See attached.
Ian
Message 9 of 12
(4,332 Views)
Message 10 of 12
(4,328 Views)
