Type mismatch error in excel read.vi
I am having a simple issue in one of the sub vi's in the attached program. It seems to be in the variant to data process.
I get a type mismatch error. I am sure there is a simple explanation, I just can't seem to figure it out.
I  have attached a simple excel file that I have tried to read.
Thanks in advance for your help
(3,288 Views)
You forget to add, all of the subVIs, which constitutes the main VI that you had attached.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,277 Views)
Sorry about that,
I have attached the sub vi's.
(3,271 Views)
Here is a .jpg of the block diagram.
(3,270 Views)
There are many other components (VIs & .ctl) are still missing, find the attached list of the same (Missing VIs OR ctls.doc),
Anyways attached is an example VI, that I use to read excel files, you may want to try that.
(3,257 Views)
Sorry again,
I downloaded these VI' from here as a toolkit. Almost all of the VI's run execpt the "read" VI's
Thank you for the VI I will see if it will work.
(3,254 Views)
