‎08-02-2018 06:22 PM
What is better, using a type definition or a class to define a collection of data elements? Can you share interesting use cases for one over the other? Type defs are simple and dumb, while classes could allow various types of formatting to be applied when getting or setting data.
Other thoughts?
‎08-02-2018 08:25 PM
Other thoughts?
These concepts are not either or not better worse.
A class may contain a type defined data element. A type def might include a class.
Give us an example of what you have. With the data structure in question and in context of where you might use it. I guarantee you there will be vigorous proponents of both parties
‎08-03-2018 08:06 AM
A type def is nothing but a definition of the data type. A class is a set of private data and methods to act on that private data. If you go into the NXG paradigm, they are actually the same thing, you just choose what level of "classiness" (couldn't think of a better term) the gvi will be.
So, it really depends on exactly what you are trying to do with the data. I use both very regularly.
‎08-03-2018 08:16 AM
I too use both regularly, but I can't say I use them consistently. I suppose what prompts this question is the available functionality to right click on a type def to convert it to a class. It sort of seemed like there is the encouragement to use classes instead of type defs, but maybe I interpreted incorrectly...or I was jumping ahead to the NXG paradigm without knowing it.
‎08-03-2018 09:05 AM
Let's reduce this a little more and speak specifically about clusters and access to data in it. Now the question breaks down to if you want the user of your functions/API to have direct access to all of the values in that cluster. As I am developing APIs, I am increasingly finding that the user does not, and should not, care about all of the data I am storing in the state. Therefore, I am using classes more and more to maintain a state.
For example, I have a library for communicating with a power supply over an Ethernet connection. Do I really want the user to be able to randomly change that connection reference? Absolutely not. Bad things are likely to happen. Therefore, I hide details of the library by using a class. I then also get the benefit of Dynamic Dispatch to further expand capabilities.
‎08-03-2018 09:08 AM
I'm a one man team when it comes to programming, so I'm not often keeping other programmers in mind. Now that I am revisiting a lot of code, maybe doing some rewrites, your use case sounds like a pretty good approach and would probably help me when reviewing old code down the road.
‎08-03-2018 09:33 AM
That is the wrong attitude. Because you will be that other programmer when you try to reuse a library 6 months from now. Thinking in terms of APIs has helped my code base immensely.
‎08-03-2018 09:36 AM
I entirely agree. My todo list for the summer contains "improve LabVIEW skills" 🙂
