Typdef property node bug when converting from non-strict to strict
I had a typdef'd tab control that I turned in to a strict-typdef and suddenly I got coercion dots everywhere I used a property node (both implicit and explicit). That was annoying cosmetically, but I considered it a minor issue. Then I added a tab to my control and suddenly all of my property nodes caused broken wires; it appears the property node is not actually linked to the typedef.
Fortunately I only had a handful of property nodes, so this wasn't a huge deal for me, but figured I'd post here for public information/additional insight. I do have an open support request and will update with a CAR number when it becomes available. I discovered it using LabVIEW 2017 SP1 f4, but it reproduces in 2019 f0; haven't looked to see if there are any patches available yet.
For those curious, to reproduce it using the attached code:
1. Open the VI; observe there are no coercion dots.
2. Open the typedef. Change it to strict and apply changes. Observe coercion dots.
3. Add a tab to the typdef. Apply changes. Observe broken wires.
I believe this also reproduces vice-versa (going from strict to non-strict), but haven't fully tested that path.
(2,524 Views)
Update:
IFF you break the wire by changing the altered typedef, saving or force recompiling both resolve the issue (broken wire AND coercion dot), at least with a tab control. Just saving/force recompiling does NOT fix the coercion dot if the wire isn't broken.
(2,476 Views)
If I read you correctly, you are talking about a tab control that is a type def.
I gave up trying to type def tab controls back in LV 7.1 figuring that that was not supported since they never updated and I had manually update any refs to tab control it they changed.
So this is news to me!
Ben
(2,448 Views)
The case I attached is with a tab control, but the issue seems to reproduce with ANY typedef, from what I can tell.
(2,433 Views)
Update: Apparently this is expected behavior that I've somehow never noticed before.
According to support, the propagation only occurs when a structural change is made to the typedef, thus coercion dots until that occurs. From what I can tell, the propagation still doesn't occur automatically, thus broken wires all over the place until you manually force it to propagate by hitting the run arrow or saving.
(2,394 Views)
I have muscle memory that goes...
Apply Changes
Save All
(lather rinse repeat if it is a nested type def)
Then closing the type all is OK.
Side Note:
Switching from a type def to a strict and doing the above dance
AND THEN
Switching back to a normal type (again with the muscle memory dance) allows me to force all to look the same but still have to option to hide-show that an normal type def allows.
For what it is worth...
Ben
(2,385 Views)
