Two while loops at same time: one RS-232 serial one GPIB communication. possible?
hello,
The lab i'm working in uses labview to perform spectroscopy measurement.
would this be possible: one while Loop "A" that receives data through GPIB at a desired interval of time, and one while loop "B" that receives data from another GPIB instrument and then output a byte of word through serial comunication. Loop A works perfectly on its own..but if i try to run both loops together, would there be conflicts? if no, then loop A i'd like to run at user defined interval of time ,and loop B as fast as possible. would that be possible?
thank you very much for your help!
***The following is supplemental information on the loop as it is not necessary unless interested in knowing***
we have a GPIB instrument that reads voltage of our sample and a simple mathematical equation converts that to a temperature, and we 'd like to read that temperature constantly and as it changes, we change the output of our PIEZO box (a thing that can output from 0 to 10 volts of current). piezo box uses the standard serial communication. so in a way a simple/fake PID loop to keep the temperature stable. the output of piezo is connected to a thermocouple which heats up our sample.
the same time, we also have a "camera" that is communicating through GPIB, that records the spectrum of the sample and display it on a XY graph. we'd like that camera being continuously running as well. so it will keep taking picture one after another interval of 1 second at the same time as the first loop keeping the temperature stable.
(2,591 Views)
You can have two While Loops running in parallel.  You can even code it so that they use a particular CPU code.
However, the GPIB bus does not support parallel communication.  It can be near "parallel" especially if coded in such a way to synchronize the commands, but they may get to the instruments a few ms apart.  That is a restriction on the GPIB bus, not within Labview or the While Loops.
(2,576 Views)
