Two signal pulse
I have two pulses which are dephased of 90degres.
To know if my motor is turning clockwise or counter clockwise, I have to know if the second signal is to "1" or to "0" when the first signal is going from "0" to "1".
May I know which block I could use in Labview to do this?
Thank you very much,
Alexander
(3,379 Views)
You've got three threads going with the same question. Here are the other two threads.
http://forums.ni.com/ni/board/message?board.id=170&message.id=261932
(I responded to this one)
and
http://forums.ni.com/ni/board/message?board.id=170&message.id=261930
Message Edited by Bill@NGC on 07-27-2007 05:22 PM
(3,368 Views)
(3,355 Views)
the subject of this thread is not the same as the others.
The only similarity is that there is two pulses.
I thought it was wiser to separate the threads instead of having one big thread with three conversations. Everybody would have been confused.
I will explain my whole problem in the thead
Alex
(3,323 Views)
 Hello Alexander,
 This is a quadrature encoder application. Please take a look at this document:
 What DAQ device are you using?
The X1 Encoder is supported by most of our devices with counters, X1 will increment counter on rising edge of A when A leads B, decrement on falling edge of A when B leads A.
 Have a great afternoon,
 MatthewW
(3,301 Views)
