Pulse count
I have a pulse  and I would like to know how much pulse have been obtained since the start of the program.
All I can obtain is the time delay between two pulses.
May I know where the block to count pulse is?
Thank you very much,
Alexander
(3,428 Views)
You've got three threads going with the same question. Please use the thread below for this question, it requests more information from you:
http://forums.ni.com/ni/board/message?board.id=170&message.id=261932
(3,419 Views)
Guess it would help if the thread I referred you too was hyperlinked.....Smiley Wink
(3,409 Views)
 Hi Alexander,
Please keep your posts on the same topic (counting digital events) to a single post.
This is very similar to the first answer which I posted here. To count a total number of
 pulses (up to terminal count), you would want to use a counter in Simple Event Counting mode.
There is a example that does exactly this, please take a look at:
   Count Digital Events.VI
Please reply to the linked forum location above, this helps keep our community clean of parallel
threads on the same topice.
MatthewW
(3,368 Views)
