Two analog inputs with DAQ Card 6062E
I am trying to acquire two analog inputs from a DAQ Card - 6062E with a 68 screw board terminal. I have attached the VI with this message. I am getting the 50103 error, which has been posted in several forums. I tried several possibilities posted but couldn't get the result at all. In addition it shows 200088 error too. The program in the case structure is horrible (not done by me, I am just adding the event structure to acquire angle) but that is not of concern here I guess. I am on a bloody time crunch here so, any idea or suggestion would be really really helpful!
Thank you very much in advance.
(2,898 Views)
You've got two separate DAQ tasks accessing the same card.  The AI only has a single clock on it and by spinning up two separate tasks, you're trying to instantiate the clock twice.
ColeR
Field Engineer
(2,871 Views)
Hi, I tried with the same task too, but it doesn't seem to work. Any suggestions to reconfigure?
(2,861 Views)
Hi, I worked it out somehow and I'm not getting the error! Thank you for the help! 🙂
(2,854 Views)
