Two Button dialog - Fire once
I have an application where I need to get many responses from the user by way of two button dialogs. I need to sense the state change of a latched DI and when it goes HIGH, display a two button dialog box for the user to interact. Since this happens inside a 100ms while loop, I need to supress the dialog box after user choice is made. Otherwise the pop up will happen repeatedly as the DI is latched in HIGH state.
While I have been able to get the functionality with a shift register ( refer attachment in LV2009), I was wondering if there was a better way to do these kind of "once-only-messages" ?
Raghunathan
LabVIEW to Automate Hydraulic Test rigs.
Message 1 of 12
(6,512 Views)
I would just do it with a shift register.  You may be able to use some boolean logic with using the Implies boolean function.  It could possible minimize the embedded case structure, maybe even eliminate a shift register.  But I find the Implies function is not always easy to get working correctly right away, and may not be as easy to decode when you look at the VI later on.
Message 2 of 12
(6,503 Views)
I agree with Ravens - what you have may seem like a lot of wires to do a simple task, but it's in keeping with the dataflow idea.
Richard
Message 3 of 12
(6,494 Views)
Well, you don't really have a 100ms loop, because the dialog box stalls the loop forever, or until the dialog is completed (whatever comes first ;)).
Is this acceptable? Personally, I don't like such dialogs. They are annoyong to the operator.
Here's a simpler version that only uses one feedback node.
Message Edited by altenbach on 02-05-2010 09:06 AM
Message 4 of 12
(6,487 Views)
The version is simpler. But there is one glitch. The lamp once switched ON remains so even when the switch is toggled to the "Disable" position.
Raghunathan
Message 5 of 12
(6,449 Views)
Perhaps you want something like this.
I moved the lamp indicator outside so it is always written to.  I also put a local variable for Enable Link inside the false case so that if you select no in the dialog, the switch returns to false.
Message Edited by Ravens Fan on 02-05-2010 08:47 PM
Message 6 of 12
(6,445 Views)
Accepted by topic author MogaRaghu
It is not a good idea to change the state of the Digital Input which is "Read Only"
The final VI with the required modification is as below :
Raghunathan
Message 7 of 12
(6,393 Views)
where can i find these?
Message 8 of 12
(5,034 Views)
Message 9 of 12
(5,028 Views)
Hi Dany,
the other is a FALSE boolean constant from LabVIEW before LV2011 (or LV2010)…
Message 10 of 12
(5,013 Views)
