Tutorial (Getting Started) VI
i am trying to run the "Opening a New VI from a Template " tutorial and it mentions
"3. From the Create New list, select VI»From Template»Tutorial (Getting Started)»
Generate and Display. This template VI generates and displays a signal."
i can not find "Tutorial (Getting Started)»Generate and Display" in the list of VI's after selecting NEW. where am i going wrong
Message 1 of 9
(10,442 Views)
What version of LabVIEW are you using?
I find that vi in LabVIEW 2013 sp1 at the top tool bar: File>>New...>>VI(folder)>>From Template(folder)>>Tutorial (Getting Started)(folder)
Hope this helps
Now Using LabVIEW 2019SP1 and TestStand 2019
Message 2 of 9
(10,433 Views)
File->New...->
In the Simulated group you can see the Generate and Display. If you dont have this, which LV are you running? This picture is from 2013.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 9
(10,428 Views)
Did you expand the "from Template" section?
(Not sure if this is needed, but do you have DAQmx installed?)
Message 4 of 9
(10,427 Views)
Hi ,
i am using 2014
i do not see the Tutorial (Getting Started) in my VI's
Message 5 of 9
(10,383 Views)
Yes, you are right. I cannot see it in 2014. I'll investigate.
Message 6 of 9
(10,371 Views)
however if you create  new VI from >>Simulated>> Generate and Display it seems to behave as you would expect the Tutorial VI to behave, i started it this afternoon following the rest of instructions from the LabVIEW Getting Started pdf, and it seems to work.
Message 7 of 9
(10,363 Views)
Just to close the loop on this, the Getting Started with LabVIEW manual was deprecated in LabVIEW 2014. Because of this, we removed the New... templates that were used alongside this manual.
All getting started material related to LabVIEW is now available here: http://www.ni.com/getting-started/
Message 8 of 9
(10,273 Views)
thanks to all for responding, i think i am now on the right track
Message 9 of 9
(10,252 Views)
